Charru33
[SOLVED] No data for Lycamobile Spain
Wed May 23, 2018 12:42 am
Hello, I'm writing you from Spain and my carrier is Lycamobile, my issue is that i can't have data on my phone, I have no problem with the wifi, but when it comes to data there's no way to connect, I've configured carefully the APN settings following exactly the instructions of Lycamobile, I called them to configure it themselves but it did not work, I've tried to put my sim card in my wife's phone (Moto G4 Plus) and it works perfectly with the same APN settings, so the problem is not the sim card or the APN settings, What can it be?. One more thing (may be useful) there's a little "R" next to the 4G signal indicator, thank you.
Re: No data for Lycamobile Spain
Thu May 24, 2018 8:43 pm
Lycamobile gave issues also to another user in UK:
viewtopic.php?t=343661
"R" stands for Roaming, try to disable it.
Try also to follow that:
viewtopic.php?f=191&t=349626
Report back if it works ;)
Don Harry
Thu May 24, 2018 9:28 pm
Have you tried this steps (by Lycamobile España):
https://www.youtube.com/watch?time_cont ... IWnHfr7r4A
Charru33
Mon May 28, 2018 1:17 am
I've tried it all, still does not work  :(
Charru33
Mon May 28, 2018 1:25 am
Of course, it was the first thing i tried
Mon May 28, 2018 8:28 am
I guess that the only solution would be sticking to another (and better) carrier...
Charru33
Fri Jun 01, 2018 7:55 am
I didn't think about it, i will try it with another sim card and tell you  ;)
Fri Jun 01, 2018 7:11 pm
Great, will wait for your feedback! ;)
