pavanhuliyar
[SOLVED] BV8000 Pro Data not working in UK
Sat Dec 30, 2017 4:30 pm
Hi, I bought BV8000 Pro two days ago and i'm using it in UK with LYCAMOBILE network. I am not able to connect to mobile data network. I've tried 4G and 3G both and none of them work. I am guessing LYCA mobile's bands are not compatible with this phone. But, even if want to switch, i am not able to figure out which other network provider in UK is compatible with this phone. EE, O2, Vodafone, Lebara... Which one should i use?
Re: BV8000 Pro Data not working in UK
Sat Dec 30, 2017 4:36 pm
It's not about the bands, but about the APN settings, provided by your carrier, that you have to insert into your device's settings. ;)
Contact your carrier for more infos about it ;)
ElectroStingz
Re: [SOLVED] BV8000 Pro Data not working in UK
Fri Jan 12, 2018 11:51 am
I tried an EE data sim which worked fine 4G.
Currently using 2x O2 PAYG sims which also work.
