Christian
Problems with Android 7.0
Fri Dec 30, 2016 5:36 am
Hello, I have the following problem after the update
The phone does not start with two sim cards with only one.
It is after the start possible for the first sim card
Pin. Then the field for the pin input appears
The second card. But this only very briefly and then the
Screen slightly darker and man only sees the background
image. Nothing happens.
naim
Re: Problems with Android 7.0
Mon Jan 09, 2017 5:36 pm
Just out of curiosity, is android pay working on 7.0? Thsnk you
