Christian
Problems after update Androind 7.0 Rome BV6000_Blackview_V01_20161216
Thu Dec 29, 2016 12:20 pm
Hello, after the update
1. starts the phone no longer with two sim cards
2. In the gallery, the videos no longer move
3. The volume setting remains the same
It is unfortunately still not possible to regulate the volume for the ring and for the message notification individually
The most annoying thing is that it does not start with two sim cards.
Re: Problems after update Androind 7.0 Rome BV6000_Blackview_V01_20161216
Fri Dec 30, 2016 8:33 am
Thanks so for your feedbacks, i will pass it to our software developers for improvement.
BeHa
Fri Dec 30, 2016 2:51 pm
Updated to 7.0 and having issues when i reboot phone. "Unfortunately, Launcher3 has stopped" and it is in loop starting and stoping working. Only help is to clear data/cache in launcher3 app settings. It work fine till next reboot of the phone. Any ideas?
inde333
Fri Dec 30, 2016 7:51 pm
I have also the same. After last update (android 7) application Launcher3 stop work. what can I do?
inde333
Fri Dec 30, 2016 7:59 pm
merevel
Fri Dec 30, 2016 10:49 pm
I changed launcher to other one. Now I use Golauncher.
Phil
Fri Dec 30, 2016 11:39 pm
Try to use an alternative launcher. I suggest Trebuchet, it's the original Android launcher with possibility to turn of search bar. http://www.apkmirror.com/apk/cyanogenmo ... -download/
drae
Sat Dec 31, 2016 7:03 am
i can confirm the error with two sim cards. After rebooting the BV6000 is hanging in endless loop. I found a small workaround to fix this problem. Turn off the phone and start it again with power button. Now you can type your pin code for second sim card.
Alifchaidir979
Sat Dec 31, 2016 11:01 am
Hi, please help. I cant update at all. Even for the 25 version. My OTA is not working. I've tried to post my problem but it seems the moderators never approve it. Please help me how can I update my phone because it looks like the developer doesnt even care about it.
Karmelius
Sat Dec 31, 2016 11:45 am
After the update to 7.0 I`ve got the next problem: when i open the pfone app to make a call, it`s clothing after some seconds with message "phone has stopped". So now to make a call i`m using contacts app, but it`s really uncomfortably!
