vermondr
volume problem can't almost hear my phone ring anymore
Sun Dec 25, 2016 2:00 pm
I have a big problem with the volume sound of my bv6000 phone.
I bought it in september and the sound was great, it was at max volume verry loud, so i had to put it lower.
But now at max volume and lies on the table you don't
It happend two weeks ago. I think it happend after the latest update bv6000_Blackview_V01_20161025_20161108-1812.
I did the factory reset and hoped to go back one version, but it keep the same version 20161025.
Do i have to send the phone back or is it realy a bug in the software?
Do i have to wait for a new updat?
Or do i have to wait for android 7.0?
When will i get 7.0 the release was the 24 of december.
Can blackview_admin response to my problem!
Re: volume problem can't almost hear my phone ring anymore
Mon Dec 26, 2016 8:30 am
You can contact the service@blackview.hk to get a loudspeaker replacement.
Phil
Mon Dec 26, 2016 10:15 am
@Admin do you know when the first exchange loudspeakers will or had been sent out?
bvbw
Mon Dec 26, 2016 10:50 am
Alston tell me it will be send in February.
joaquim moita
Thu Jan 05, 2017 11:59 pm
In my case the loudspeacker has a low sound with strange noises.
On November I altready asked to service@blackview.hk a loudspeacker replacement but no one anwser to my emails.
Can you provide it, please?
naim
Mon Jan 09, 2017 5:48 pm
Messing around with MTK engineer mode might end your misery and restore your volume. That is if the speaker is not mecanically damaged...
manu r
Fri Jan 27, 2017 4:49 pm
salut ça faisais 2 mois que le son de mon haut parleur arrière ne fonctionnait plus, je ne pouvais plus attendre, j'en ais commandé un sur internet sur ..... pour 20€ et alleluia tous refonctionne parfaitement. quel bonheur :D
service@blackview.hk je leurs ais envoyé des mails avec tous les documents demandés et pas de nouvelles sur la réception d'un haut parleur....
cordialement
Manu
