qatrunada
Invalid imei after update with flash
Sun Dec 18, 2016 6:51 pm
I have trying update my bv5000 last night, after it done.. My Phone dont have imei number, without it i cant using network . litter help would you?
drupi
Re: Invalid imei after update with flash
Wed Jan 11, 2017 5:51 am
Did you solve your problem?
If not, I had the same problem with an BV6000 and I've used SN writer, search on youtube.
You also need unzzipped ROM - you need two files from it.
qatrunada
Wed Jan 11, 2017 5:58 am
all ready fix it, using *#*#3646633#*#* and try input imei dozen time and it work at last. haha.. now i have bv5000 with android 6.0
