BeHa
Charger broke.
Sun Dec 18, 2016 11:40 am
After 2 months of using the charger broke. Yesterday it worked fine but today it is not at all. Where can I buy original charger for this model?
Re: Charger broke.
Mon Dec 19, 2016 6:13 am
you can buy it directly from online stores.
BeHa
Re: Charger broke.
Mon Dec 19, 2016 10:05 am
Can you post me any link to this store because on aliexpress or gearbest are only for bv5000 or 2000. I can't find ORIGINAL charger like this one delivered with phone.
Re: Charger broke.
Tue Dec 20, 2016 5:57 am
If you can not find one on online, please contact our after-sale team directly for spare part buying.
Phil
Re: Charger broke.
Tue Dec 20, 2016 12:59 pm
https://www.aliexpress.com/wholesale?ca ... r+original
BeHa
Re: Charger broke.
Wed Dec 21, 2016 9:23 am
It isn't the same charger.
Phil
Re: Charger broke.
Wed Dec 21, 2016 10:54 am
It is the same original charger I got with my BV6000. If your one is an other one please post a photo.
But nevertheless you can buy that chargers I sent you on Aliexpress, its working very well (with EU-Plug size).
ThomasSc
Re: Charger broke.
Wed Dec 21, 2016 3:40 pm
I got this chargers for my two BV6000.
Charger BV6000.jpg (198.18 KiB) Viewed 4787 times
Phil
Re: Charger broke.
Wed Dec 21, 2016 9:58 pm
Sorry, you are right. I got the same like you and the ones at Aliexpress look a bit smaller. Does anybody know if they are newer and compatible with bv6000 fast charge?
BeHa
Re: Charger broke.
Thu Dec 22, 2016 9:12 am
I got the same and I can't find original on the web.
