decayedsin
4G always crashing and restarting on phone when on the internet
Wed Mar 23, 2016 8:54 am
Good Morning,
I have been waiting for some time for new updates and hoping for a fix on this issue.
Every time I try to use the 4G internet for voip or browsing, the 4G signal on the phone just crashes and restarts after a while
on the phone. Please fix this bug.
Also the option to set diferent ringtones on each sim card would be a plus for your phone, like other phones have.
I had a previous phone Doogee DG700 and I could set different ringtones on each sim card.
Thank You.
Re: 4G always crashing and restarting on phone when on the internet
Thu Mar 24, 2016 8:40 am
hi,
the 4g signal is weak in your place ?
we feel so sorry you can set different ringtone for different contacts , but can not set different ringtones to identify the sim card!
Best regards,
Admin
decayedsin
Thu Mar 24, 2016 10:54 am
No, the 4G is at max, it is a software bug on the phone where it after a while just turns off both receiving antennas on each sim card and reboots the antenna signal.
Please fix this with an update.
Thank You
Mon Mar 28, 2016 8:37 am
Thank You
you can expect a Mashmallow Syetem via a OTA upgrade very soon.
Best regards,
Admin
