Spinebreaker
Re: Dud battery dud phone.
Thu Dec 15, 2016 8:11 pm
I would recommend you to reset it.
Turn off your phone and wait untill its copletely off (it will vibrate once).
Enter the recovery mode by keeping the Power and Vol-Up buttons pressed until the phone turns on.
The Blackview logo will show up and then you will see a green Android. Next step is a little bit tricky because you need to press a combination of buttons to enter the recovery (its like a password to avoid idiots from entering it).
Hit and release the following buttons in this order while you keep the power button pressed (you need to do it quick in a liquid motion).
Vol-Up
Vol-Down
Vol-Up
After you entered the recovery you can navigate with the volume buttons and enter with the power button.
You can do a backup in here as well that you can recover later (this might bring back the issues).
Wipe the cache and do a factory reset to see if this will solve your problem.
If not I would recommend you to reflash the rom, maybe something went wrong during the manufacturing process.
Pono
Thu Dec 15, 2016 9:29 pm
Ciao, thank you very much, I'll give it a shot,
regards Pono.
Pono
Fri Dec 16, 2016 3:11 am
Ciao, ok I tried that and it never worked, have no idea what flashing a rom is, love t to hear from blackview on this.
Pono
Fri Dec 16, 2016 8:31 pm
Anyone home at blackview?
Pono
Sat Dec 17, 2016 12:27 pm
Ok blackview you going to help me with my phone or not?
Pono
Sun Dec 18, 2016 8:34 pm
Are you all o on holiday blackview?
Spinebreaker
Tue Dec 20, 2016 9:16 pm
I still dont understand why he is still working for Blackview.
In Germany he would be fired already. But thats China I guess...
Maybe this will help you a little bit.
viewtopic.php?f=152&t=92102
The rom is the software running on your phone, simmilar to Windows or Macintosh on a Pc.
The process of installation is called "flashing".
Pono
Wed Dec 21, 2016 7:01 am
Sighhhh I don't have windows 10. Thanks for your help Spinebreaker, blackview should be paying you instead (-:
Pono
Sun Jan 15, 2017 10:19 am
so much for replies in one day admin. has been a month
