adepoyu
Not able to update
Wed Dec 14, 2016 10:39 am
I'm in BV6000S_Blackview_V01_20160913 and Wireless Update reports there's an update available BV6000S_Blackview_V01_20160929.
Updating with Wireless Update gives an error in th middle of Android installation (when showing installation bar progress after reboot).
Using the local update as instructed here viewtopic.php?f=144&t=41724 doesn't give any errors, but the update is not applied. I'm still in BV6000S_Blackview_V01_20160913 after it finishes.
Is there any other way to perform a successful update?
Thank you!
Re: Not able to update
Fri Dec 16, 2016 6:54 am
adepoyu wrote:
Thank you!
Where you get the local update file, can you show us a link?
Glu777
Wed Dec 21, 2016 1:56 pm
Hi, I have the same problem with 20160929 update via WiFi. How to solve problem?
