admin
Site Admin
How to ROOT under EngineerMode
Sat Sep 19, 2015 3:05 am
How to ROOT under Engineer Mode picture instruction.
1.Power on your phone
2.Dial the number:*#9646633#
3.Choose"Log and Debugging" and find "User2Root"
4.Click"Root" to turn on ,"User" to turn off.
Default turn off if your phone restart,please turn on each time if you want to root
5.Successful
DjxAndroid
Re: How to ROOT under EngineerMode
Sat Sep 19, 2015 3:00 pm
5.Successful
hahah lol admin, not found -.-
cryback79
Sat Sep 19, 2015 6:23 pm
not working
DjxAndroid
Sun Sep 20, 2015 12:09 am
cryback79 wrote:
not working
hahaha and of course the only way and as I said from the recovery, partly because to make the root you will need a program called supersu or super user, and the method has not posted admin you install this program, it is no use this method, indeed admin mail link scatter firmware stock good, because as soon as you load the scatter from checksum error I hope I explained
Bumblee23
Sun Sep 20, 2015 10:52 am
Very hard to read and understand your writing with as good as no punctuation marks.
@Topic: This method doesn't enable the "classic" rooting you may think. Would be too easy.
But even flashing SuperSu with costum recovery like twrp doesn't grant root by now... :?
cryback79
Sun Sep 20, 2015 10:01 pm
Hi @DjxAndroid,
You're right, that's why I asked for a custom recovery.
I wasn't able to contact you, PM is is outbox. Can you contact me with it?
Regards,
admin
Site Admin
Mon Sep 21, 2015 6:02 am
any problem you can post here and we will do our best to help all of you.
Phantom
Mon Sep 21, 2015 9:17 am
I also try to root the phone to no avail . Have already tried a lot , but had no success .
Simple question : Is there a method that P1 Pro root if so how? Please precise description how .
DjxAndroid
Mon Sep 21, 2015 4:33 pm
cryback79 wrote:
Hi @DjxAndroid,
Regards,
So guys, I managed to rootare this phone, the process is not difficult, but it will void your warranty, you must first make a copy of your stock ROM, depending on what you need to install a recovery and from there to flash a zip file buffer in superuser now have root permissions, if you do not understand something, you can write in youtube channel DjxAndorid, are Italian and are appssionato phones and modding on Android devices, if you can write something cpite channel greetings
ps x admin controls please let the checksum of rom stock, by mistake in loading the files scatter
admin
Site Admin
Tue Sep 22, 2015 2:00 am
viewtopic.php?f=3&t=9
did you watch this?
may can help you
