DocNightfall
Vibration motor stopped working
Thu Dec 08, 2016 3:57 pm
All of a sudden today, my BV6000 stopped vibrating on tap while typing, and also doesn't vibrate when ringing anymore. I rebooted the phone several times already, and rechecked the vibration settings. I also downloaded an app that manually activates the vibration motor, but nothing happens still no vibration.
Re: Vibration motor stopped working
Fri Dec 09, 2016 6:04 am
A factory reset may help you.
And before a factory reset, don't forget to back up your information and data first.
jan674
Thu Feb 02, 2017 4:24 pm
I do have the problem with the vibration motor too.
I tried to reset my phone, but no success!
What I realised is, that the motor works by shock.
Is there any other possibility to fix the issue?
