Phil
Change from WiFi to 4G don't work since update to 20161025
Sat Dec 03, 2016 2:16 pm
Since the update to Firmware 20161025 I noticed a big issue: After changing from WiFi to 4G mobile data there is no possibility data connection. I see the 4G Icon and good connection strength but it seems I that I don't even get an IP adress. There is no difference if I turn of WiFi manually or connection got lost and no difference if VoLTE is turned on or of.
When I turn flight mode on and of again 4G connection works well again. Changing from WiFi to 3G is possible without problems. Factory reset don't help.
Please provide help for this big issue!
Users browsing this forum: No registered users and 14 guests
