Ariey
Default Languages
Sat Dec 03, 2016 4:47 am
Hello Blackview team. I have just upgraded my Android to Marshmellow 6.0 yesterday at Blackview service center and then i upgraded it to the latest version. Everything works perfectly but i noticed my default language is Bahasa Malaysia. I changed to English (United States) but for some reason it keeps changing back to Bahasa Malaysia on its own. How to solve this problem?? I prefer using English as my default language. Pls reply A.S.A.P and help me.
Re: Default Languages
Fri Dec 16, 2016 8:56 am
usually, your local sim card will help the device to automatically setting to your local language.
But you can still change the language to the one you need on setting menu.
The language will change back only after you reboot it or do a factory reset.
alexquah
Sun Apr 09, 2017 5:05 pm
hi black view, means I cant fix or lock in to the language I want ?
Damiens
Wed Aug 02, 2017 3:10 pm
I have same problem.if i reboot my bv5000 the language always back to local language?could you help me for this problem
