Fajar
Failed installing after download fota update (wireless update)
Fri Dec 02, 2016 11:12 pm
My bv6000 has standard software.. No root.. My rom v01_20161011
I got fota download notification, after downloaded bv6000 my phone has restart.. Then the screen show me a picture of green android and start installing.. After a moment it was an Error icon on my screen.
I have to try download fota for a twice,, but the result as the same.
Please help me to fix this problem
velmafia
Re: Failed installing after download fota update (wireless update)
Sat Dec 03, 2016 10:15 am
I have the same problem.
Also official ROM (v01_20161011) without any changes.
costi31
Sat Dec 03, 2016 11:37 am
I have exactly the same firmware version and the same problem installing the ota update :(
nyfd_it
Sat Dec 03, 2016 12:25 pm
Similar problem: after the fota download, launched the update, but the phone not restart and the update not go ahead.
ThomasSc
Sat Dec 03, 2016 12:29 pm
Same here.
Aerotrancer
Sat Dec 03, 2016 12:37 pm
Same here (Germany)
Sagittarius
Sat Dec 03, 2016 2:24 pm
I habe the Same Problem. Pleas help,becaus the Handy is a ggift for my dady to Christmas! :cry:
6000 user
Sat Dec 03, 2016 3:00 pm
For me it worked OK. But I don't remember which was my last version.
Phil
Sat Dec 03, 2016 4:20 pm
I had no Problem with the same update. Maybe Blackview can provide a Download file for a local update for you.
maciej.roch
Sun Dec 04, 2016 7:44 am
I have the same problem with two phones this last update fails with the error :oops:
