aztec165
Last update folder problem
Fri Dec 02, 2016 8:25 am
I recieved an uptade this morning,
After this update all my application folder created on each screen are disappeared! What's a problem, i have to pût away after each update!?
i use a BV6000 since the midlle of october 2016 , unstoppable phone !
Tomator
Re: Last update folder problem
Fri Dec 02, 2016 8:45 am
Maybe system some setting had to be reset.
I didn't like the default launcher application and switched to Google Now. No folders or widgets were changed during update to 20161025.
BV6000 P2 BV9500Pro
dee-san
Fri Dec 02, 2016 11:47 am
Same for me; I had to recreate all my folders - but it's not too bad if some bugs got fixed :)
