Roma960
Connect with PC
Sun Mar 13, 2016 2:45 pm
How I can connecting with PC: I tried to connect using a cord - CP requires drivers. All have been found on the network did not fit. By the Bluetooth - is not connected, so it is not possible to enter a code on your phone and on the PC. How to connect to download software, music, and images, and how to put ringtones on your phone calls?
Re: Connect with PC
Tue Mar 15, 2016 8:43 am
Hi ,
you mean you can not find the driver to connect to pc ?
Best regards,
Admin
folan
Re: Connect with PC
Tue Mar 15, 2016 12:37 pm
hi
try MyPhoneExplorer, install it on the smartphone and the computer ...
Evatibra
Connect with PC
Fri Mar 24, 2017 9:03 am
I am trying to create a network of ardrones. And i know how to connect ar drone drone to acces point. However i m stucked on how to connect a drone to another which is connected to an access point
eg :
Access Point<<<<<<<<<<<<< AR DRONE <<<<<<<<<<<< AR DRONE
Any thoughts on how to do it ?
Ramondes
Thong Screen side Wigs Or Unimpaired Upon on Wigs
Wed Jul 26, 2017 4:15 pm
In case you are a new comer to hairpieces and want to purchase one, and then what you may Human Hair Wigs
are thinking about is you only need to select the color and style that suits you. But usually the actual purchasing associated with wigs is a touch more complicated than you've got Human Hair Wigs
dreamed.
In order to choose the right factor yourself, the very first selection you will have to create is to pick involving two types of wigs: the actual artificial Wigs For Black Women
types and also the real human hair ones. They both come in several styles and colors and still have their particular positives and negatives. An artificial hairpiece is cheap, but it is likely to look artificial in fact it is harder to take care of. Although a person curly hair hairpiece is a bit more reasonable Wigs
seeking and lasts longer, but it's costlier.
Another important thing you'll want to contemplate when selecting wigs is always that which kind of cover can be used for that hairpieces. Your Human Hair Wigs
cap 's what you'll pull over your head, a top quality cap could make you feel at ease. However, there are numerous different types of wig truck caps available to pick from, your ribbons cover is easily the most well-known one. The actual ribbons Lace Front Wigs
cap could make you feel totally cozy as it allows your crown to be able to "breathe".
Users browsing this forum: Baidu [Spider] and 8 guests
