djaafrihalim
solution of flashing bv6000
Wed Nov 23, 2016 11:18 pm
hello friends admin,
i get my problem for error STATUS_RAM_EXCEPTION.
when i am flashing my bv6000 battery was low 26% so this cause my phone is dead
what is the solution to flash it and give it live again please ? i am from ALGERIA . and i use it about 1 month only .
Re: solution of flashing bv6000
Tue Nov 29, 2016 7:05 am
So it is a power off stops the flashing, then cause the phone can not power on ?
deeWeebz
Fri Jan 06, 2017 8:58 pm
Hi there,
I get the same problem after trying to downgrade from 20161025 to 20160608.
i get my stuff working installing 20160822 version following this guide : https://forum.xda-developers.com/androi ... d-t3532865
Maybe it could help you.
dwiyogo68
Thu Jan 19, 2017 1:01 am
SOLVED
found a workaround for me.... maybe it works for you as well......
so i used sp flash tool v.5.1628 (win 10 64X) and the offical Blackview firmware 20160822-s12v55_jk_3m (remove checksum ini)
open flashtool and go to the FORMAT area
select Auto Format Flash.... EXEPT bootloader and press play
plugin your phone holding the Volume Up button
( "By keeping the Vol-Up button pressed while you plug in the USB you activate the "Meta-Mode" which is kind of bypassing the regular download-mode. Its a kind of backdoor the Mediatek-Developers integrated in case of a bricked rom.
The Chipset is missing the original preloader, thats why its not getting recognised anymore." qoute from the blackview forum)
is successfull, plug off your phone
go to the flash tool DOWNLOAD area
load the scatter.txt from the original firmware i mentioned above
select only the PRELOADER.bin
select the DOWNLOAD ONLY option, press DOWNLOAD and plug in your phone holding the Volume up button
if finished plug off your phone
Select all files for download, download only, press download and plug in your phone holding the Volume up button again
wait till finished, plug off your phone and restart it......
hope it works for you as well !!!!
