Tim.strange
USB
Mon Nov 21, 2016 12:20 am
I'm trying to find a second USB lead. The bv6000 requires a specific USB plug. Standard USB leads don't always fit, or reach the socket.
Can anyone help with the specs I should be looking for?
Techrat3D
Re: USB
Mon Nov 21, 2016 8:04 am
I just bought a pair at Amazon, that work just fine with my BV6000.
https://www.amazon.de/gp/product/B01JFN ... UTF8&psc=1
sams
Re: USB
Mon Nov 21, 2016 12:17 pm
Or you can cut 2 or 3 mm of plastic on any USB cable with a sharp knife.
I did it on many cable.
chrisb
Re: USB
Fri Dec 23, 2016 12:45 am
This was a bad design choice by Blackview
Matt
Re: USB
Sat Dec 24, 2016 3:53 am
Slightly awkward, but not bad. A lot of cables are easily altered to fit. Things like watertightness and such mean there will usually be tradeoffs elsewhere.
iLikeBV
Re: USB
Sun Dec 25, 2016 4:53 pm
What about OTG cable? Do have anyone link for otg with longer plug PLEASE?
dee-san
Re: USB
Wed Jan 04, 2017 3:36 pm
@admin:
Isn't there at least a possibility to "extend" the usb port with an adapter?
Like this: http://image.dhgate.com/albu_375073278_00/1.0x0.jpg
But with the male side in 7mm length
Isn't this available somewhere?
~dee
Morpheus
Re: USB
Sun Jan 29, 2017 6:58 am
Users browsing this forum: Google Adsense [Bot] and 4 guests
