Dmitriy771
Grey screen
Thu Nov 17, 2016 1:54 pm
Hi!
I`ve a problem with my bv5000.
Two weeks ago I took phone to atv ride, after the ride everything was ok, display showed ok. Last friday I want to take it again with me, but display isn`t work correctly, photo you can see:
Please help me, what is it? Water inside and I must replace display or it may be problem after upgrade to android 6 by air? Or maybe something else?
Re: Grey screen
Fri Nov 18, 2016 3:40 am
try a factory reset to see if problem can be solved.
Dmitriy771
Re: Grey screen
Thu Mar 09, 2017 4:36 pm
Do you have service in Russia?
