New update of 20160929 version for BV6000s with MT6735 chip
Thu Nov 17, 2016 9:26 am
This is the rom of 20160929 verison for BV6000s.
You can download via the following link:
https://mega.nz/#!atNiERIQ!IZuQHLF8n8ea ... oIH32UltmY
please know this rom is just for BV6000s with MT6735 Chipset.
And it can be installed just with flash tools via PC.
Changelog for this rom:
1) Fix the problem " Pokemon go can not be used"
2) Fix the problem" The wifi fails to be connected after you disconnected it".
Horse
Re: New update of 20160929 version for BV6000s with MT6735 chip
Thu Nov 17, 2016 11:18 am
Will this fix the Android pay issue
Sat Nov 19, 2016 6:28 am
the changelog is listed above.
Mrridwall
Sat Nov 19, 2016 10:54 am
Hi.
Will this update come out for the BV6000S via the update thingy on the phone?
Or do i have to install it my self from the PC?
diretoria607
Mon Nov 21, 2016 12:41 pm
i not use megazone . how obtain the archive to use bv 6000 in windows 10?
Sukram
Tue Nov 22, 2016 12:27 pm
I got mine straight to the phone...
vonberg
Tue Dec 13, 2016 11:33 am
Hi, i can't install the new update. Android says error ?
What to do ?
Kind regards
bhafer
Mon Feb 06, 2017 11:26 am
Who do I know if I have MT6735 or MT6737 chip?????
Japonec
Mon Feb 13, 2017 8:18 pm
firmware from 09.29 gives the phone a deep sleep, as evidenced by the band on the chart that the battery is interrupted only in flight mode, after a firmware rollback to 09.13 from sleep in the unit to normal. I think all because of the fact that in Ukraine there is no LTE network, and the phone is constantly trying to find the network and these searches do not give the phone to sleep
correct this error
zioq3k
Wed Feb 22, 2017 5:38 pm
Is avalibe new update for this model? I need this..
