kaujo
screen touch sensibility very bad with standard protective film
Tue Nov 15, 2016 3:55 pm
Hi there, using the BV6000 for 3 days now after a slow migration from Samsung S4 active.
Android 6.0 ROM build V01_20161011 one SIMcard, one SD32GB.
The only problems I've found so far are about Bluetooth and screen touch sensibility. for the first item, I posted a separate topic.
I've put the protective plastic film that came with my BV6000 on the display and was annoyed by the poor level of recognition of my finger input.
I then replaced that film by a special german film tailormade for BV6000 phones. It became slightly better, but still was hard to bear.
Today I activated the glove mode, and it seems to work quite fine - but that is not the way it was meant wasn't it?
Thanks for illuminating me on this item!
For the rest: I am quite satisfied with my shift from S4 active to BV6000. Hope I'll tell the same in aa week or two!
Kind regards
Re: screen touch sensibility very bad with standard protective film
Wed Nov 16, 2016 9:45 am
Besides the plastic film with Blackview logo, there should be already another plastic film on the touch screen.
You do not need to add extra one to it.
kaujo
Tue Nov 22, 2016 10:16 am
Stupid me! Now it works fine! Thanks for the fast response!
