Andrew
Getting BV6000 to use 4G LTE
Sat Nov 12, 2016 9:28 pm
I'm in the USA and using Cricket wireless.
All my firmware is updated.
All my friends get 4G LTE in my city on other phones.
The BV6000 works in 3G mode.
The phone is advertised as 4G but does NOT work in 4G.
Help?
Re: Getting BV6000 to use 4G LTE
Mon Nov 14, 2016 6:50 am
if you have ever checked the 4G network brand that this device supports?
The information on our official website will help you.
http://blackview.hk/blackview-147/
FredMed
Mon Nov 14, 2016 10:25 am
I have the same problem in Portugal. Please admin, check this:
(I am on V01_20161011 firmware)
BV6000
2G: GSM 850 / 900 / 1800 / 1900
3G: WCDMA 850 / 900 / 1900 / 2100
4G: LTE 800 / 900 / 1800 / 2100 / 2600
Vodafone Portugal:
GSM: 900 / 1800
UMTS: 900 / 2100
LTE: 800 /1800 / 2600
sams
Mon Nov 14, 2016 9:18 pm
Help?
Apparently your provider use B2 (1900 PCS), B4 (1700/2100 AWS 1), B17 (700 bc) and B30 (2300 WCS) and the BV6000 can work on Band 1 (2100MHz), Band 3 (1800MHz), Band 7 (2600MHz), Band 8 (900MHz), Band 20 (800MHz).
As there is around 70 different 4G frequency band, that's something you check before buying a phone.
Sorry.
Tue Nov 15, 2016 7:01 am
BV6000
Vodafone Portugal:
GSM: 900 / 1800
UMTS: 900 / 2100
if the network frequency are compatible on BV6000,
you may need to talk with your network provider to see if they can help you.
FredMed
Tue Nov 22, 2016 11:17 am
Hi admin.
You were right. The provider did not have my 4G activated. Unfortunately, only the second person I spoke with did find the problem.
Thanks for the help and I’m sorry for the inconvenience.
Users browsing this forum: No registered users and 10 guests
