gordan
ARROW overhiting
Thu Sep 10, 2015 11:33 am
My phone is not even a month old, and there is more heating of the upper part of the phone during the normal operation, such as surfing, viewing galleries, take a shoot, also when working applications AnTuTu phone to shut down by itself due to heat, sending screenshoot where you see the temperature battery and CPU in a normal operation.
I'm not demanding users, but it does not look good to me!
And I noticed in night photography, the pictures leave some lines are not good pictures.
Perhaps to correct the upgrade, or ..? , So if you can help
admin
Site Admin
Re: ARROW overhiting
Fri Sep 11, 2015 1:22 am
1.you can reset to the factory.
2.flash it.
viewforum.php?f=23
gordan
Fri Sep 11, 2015 12:14 pm
How can to flash it, in the tutorial for the whole process of flashing ROM https://mega.nz/#F!XNxhVZZK!cPSwNmDsvL8ev3iW9V4 link does not work ?
so I can not install the driver.
And can I update the smartphone's software by TF card?
