franaba
How to connect BV6000 to PC on W10?
Tue Nov 08, 2016 1:52 pm
When I connect my BV6000 to my PC, it doesn't show i.e it is not recognized it in any modeMTP, PTP, USB Storage, MIDI or Built-in CD-ROM.
Any help will be welcome.
Re: How to connect BV6000 to PC on W10?
Wed Nov 09, 2016 6:30 am
You can try to install the compatible drivers.
download here:
https://mega.nz/#!L8dx2QSB!rjy7p4ve9URF ... 2PeDIMGfLM
didgdog
Thu Nov 17, 2016 2:06 pm
I cannot get these drivers to work on my Windows 10 PC. Anyone know if there are any other drivers out there? How come Blackview have not issued them as standard?
Ghenghiskhan
Tue May 16, 2017 10:02 am
Good morning,
I need the drivers to connect my Blackview A8 to Pc with Win 10. Thank you very much.
jungletrekker69
Sat Aug 26, 2017 12:53 pm
I also have the same problem.....suddenly today, I am not able to connect my Blackview BV6000 to my 2 laptops.
Is there someone out there who can help????
Sat Sep 09, 2017 12:50 pm
It can only be the drivers (unlikely if the issue came on two laptops) or the cable. You can buy other cables with longer micro USB plug over shops like aliexpress.
