Mario.236
the last update 20161011
Wed Nov 02, 2016 2:40 pm
In the last update, the google calnedar widget don't run fine. The fert time after restart the phone, the windget run fine but after some hours somtimes the calendar hold white or other times don't refresh the tasks.
I finish one task and de widget don't delete de task but inside calendar the task is finished.
The problem with the app Caixabank pay i think is fixed with the last update..! I need to check on the market.
Thanks.
Mario.
Re: the last update 20161011
Thu Nov 03, 2016 8:43 am
Have you try a reboot or factory reset?
Phil
Fri Nov 11, 2016 10:06 am
I had the same problem. Try to install a "second" google calendar app from play store and allow it to autostart and set it on whitelist for task clear. That should also help for the original installed calendar app widget and all third party widgeds that stop running after some time.
