I am using a BV6000 with firmware 20161011. I tried to activate "Background task clear" but in the second I leave it's settings-menu (by softkey or pressing the arrow on the screen) it turnes off again. When I am pressing the home button after activating it it stays on for a while, but when I check later it is also turned off again.
Does anybody know a solution for this problem?
