Cepamoi
MTP mode not recognized
Fri Oct 28, 2016 5:31 pm
I've bought a BV6000 recently, it works great except for one, but pretty annoying, thing. It's not recognized in MTP mode, so I can't transfer anything from my computer. I've tried to update the driver but it's not working, it says there was an error while attempting to install it.
Do you have a solution ? A driver to install or whatever ?
Thanks in advance.
Re: MTP mode not recognized
Tue Nov 01, 2016 8:18 am
your computer uses windows 10 system ?
Kagawan
Wed Nov 02, 2016 12:06 am
Cepamoi wrote:
Thanks in advance.
I have the same problem too but i got a solution that maybe you can try.
Go to Device Manager & choose update device driver for your BV6000. Then go to "browse my computer..." ---> "Let me pick from a list... ---> "Show all devices" ---> then select "MTP USB device."
