thatguyisms
2g only
Mon Oct 24, 2016 5:41 pm
Hey, my new bv6000 won't connect to t-mobile's 4g network, I updated the OS and it still won't connect. It says it regesters on the network but stays in EDGE mode. What should I do?
Re: 2g only
Thu Oct 27, 2016 3:04 am
Where are you from? if you have checked the network frequence of BV6000s to see if it is compatible with your local one?
http://www.blackview.hk/blackview-147/
