kandrian
problem with access to the Internet using WiFi
Thu Oct 13, 2016 12:22 pm
Hi, my phone has a problem with access to the Internet using WiFi routers. I think there is a problem with the nvram. I see the WiFi network name "warning err 0x10" when using program WiFi analizer. And I see MAC address: 0000000 in the engineering menu. I did not change the firmware and I did not root to the smartphone. How do I solve this problem?
Re: problem with access to the Internet using WiFi
Tue Oct 18, 2016 3:19 am
you can try a factory reset to see if problem can be solved.
