Kagawan
BV6000 Windows 10 64-Bit Drivers Problem
Fri Oct 07, 2016 1:16 pm
Hi, i got problem with drivers for BV6000. Tried everything, but still nothing happen when i flashed via SP Flash Tool. Please help.
Re: BV6000 Windows 10 64-Bit Drivers Problem
Sun Oct 09, 2016 7:29 am
Have you installed the drivers for windows 10 ?
Kagawan
Sun Oct 09, 2016 8:13 am
Yes. Still nothing. I cant flash new rom right now.
Tiz-
Sun Oct 09, 2016 10:42 am
I also have problems. If I install the drivers, I can use the Flash Tool. However, a reboot or maybe Windows update seems to corrupt the driver installation. Therefore, I have to reinstall the drivers (and boot windows without driver signature verification) each time I want to use the flash tool. Maybe the correct driver is replaced by Windows update or the Windows driver repository?
robby
Mon Oct 10, 2016 2:03 am
I also have the windows 10 and windows 8 problem with device drivers. The device has been tested OK with windows 7 Pro.
Fault Symptom....Device does not get detected on windows 10 , Windows 8 and server 2012. Windows tries to compensate by installing a generic driver that is not compatible with Android 6 platform on this device. Windows 7 seems to not have this issue at all.
is there a location I can download a win 10 compatible driver from ?
Mon Oct 10, 2016 5:53 am
you can download the win 10 compatiable drive here:
https://mega.nz/#!L8dx2QSB!rjy7p4ve9URF ... 2PeDIMGfLM
Mon Oct 10, 2016 5:58 am
if they win 10 suitable driver we provide still fails to work, then you can find a find a
solution from this PDF file:
https://mega.nz/#!H8UECTJB!BPTzYIC9JAeP ... tn3Is8_s30
Kagawan
Mon Oct 10, 2016 12:42 pm
Its ok. I will try using win 7.
tmsjaeger1
Sat Apr 15, 2017 1:00 pm
can you please help.
I tried all drivers available, but when i connect the phone to flash it still says device not recognised.
Im using windows 10, 64 bit
Thank you
Regards
Tom
