Chris
Recognition of the phone in France for the use of 4g
Thu Feb 18, 2016 10:09 pm
Hello, I present you my problem:
My operator does not recognize my bv5000 BlackView because it was not declared to the GSMA. Because of that, even if my phone is compatible 4g, than my operator recognizes it as 4g, I can only use 3GB of data per month instead of the expected 50GB. My question is: count you declare all your models of phones at the GSMA?
Re: Recognition of the phone in France for the use of 4g
Fri Feb 19, 2016 6:02 am
hi ,
could you tell me where you from and if your simcard can work 4g in other model ?
Best regards,
Admin
