Tomron
Audio at video capture way to silent
Thu Sep 29, 2016 9:42 pm
Just made some videos with the BV6000, video quality is good, audio is poor. Sound level of audio is way to low, I have to be as close as possible to the microphone or scream at a certain distance to hear something in the video clip?
Is this a SW issue? amplifaction factor not set right?
there is also noise in the background but I think this is because the sound level is to low.
on the other hand when i watch youtube videos or play music the volume level is pretty much ok
BV6000 Rom on 20160822
How to flash GSI ROM, TWRP, rooting, mircoG, Magisk and other stuff - Join our TG Groups:
BV9800 Channel https://t.me/BV9800_Series_Infos and
BV9800 Chat: https://t.me/BV9800_Series_chat
BV6000 Channel: https://t.me/Blackview_BV6000_Infos
Re: Audio at video capture way to silent
Fri Sep 30, 2016 3:29 am
We will release a new rom to improve the performance. things is under testing, please wait patiently.
MasaKini
Fri Sep 30, 2016 8:12 pm
I have that problem too.
This is one of my problem about audio.
I'm using this app to create a video tutorial within BV6000 :
https://play.google.com/store/apps/deta ... order.free
The video result is quite good but the audio is too low.
I still have another problem, but I will write later.
Tomron
Fri Sep 30, 2016 9:33 pm
nezdravanul wrote:
I solved this problem by modifying settings in engineer mode mtk (app) under hardware testing/audio/audiorecord/camera recording/ul gain=248.
very good tip nezdravanul!!! the gain was at my BV6000 somewhere around 112, i set it now to 248 and even at quiet speech the audio is very good to understand!
for all others with the same issue install this app https://play.google.com/store/apps/deta ... rter&hl=de and head to the sub menu like nezdravanul proposed: hardware testing/audio/audiorecord/camera recording/ and change the gain value
Thanks for that!
@ADMIN... maybe you take this info to your Software development team to bugfix this in the next release!!!!
never the less the volume is now right, the background noise still remains!!!
@nezdravanul do you have the same issue with the background noise??
woedie
Tue Oct 04, 2016 3:29 pm
thanks this solves the issue!!
MasaKini
Thu Oct 06, 2016 2:56 pm
Thanks for that!
I have background noise issue too.
I don't know yet, how to handle that.
My experiment settings inside MTK Engineering Mode is failed.
Any idea how to fix that ?
