dukulis
Issues with proximity sensor
Thu Sep 29, 2016 6:28 am
Firmware 20160822, during a phone screen on and off several times, sometimes false-touch flash activation and launches the application. very annoying problem !!!!
Tanzit
Re: Issues with proximity sensor
Fri Oct 07, 2016 9:53 am
I have the same issue too. Sensor not sensitive enough. I tried to solve it with engineer mode but no success....
HELP HIGHLY REQUIRED !!!
Tanzit
Sun Oct 30, 2016 10:01 am
Go to developer mode, the proximity sensor calibration menu is at the end... Best regards
Andrew1974
Wed Nov 16, 2016 3:36 pm
Hi
It happens to me too. Some solution?
Thanks
danny10461
Wed Nov 16, 2016 4:13 pm
The only solution I found is press the turn on/off button at the beginning of the call and then the screen turn off and I can't touch anything with my face. When I want to finish the call, I have to touch another time the on/off button and the screen wakes up and then I can finish the call.
Don Harry
Wed Nov 16, 2016 5:49 pm
This is a new ROM of BV6000.
Download link:
https://mega.nz/#!W40T0JzS!cZi2Kf3ZOQp4 ... 0beOOAfHFo
a. No notification will be showed up about the device has been rooted when install a certain of applications;
b. The max volume of the recorded videos has been optimized to more louder and clearer;
c. Correct language mistaken of the Russian user interface;
And please know that this rom can be just installed via local upodate.
if you do not know how to do a local update, please visit the following link:
viewtopic.php?f=144&t=41724
Andrew1974
Wed Nov 16, 2016 6:28 pm
Hi
Thanks but...
I already have this rom...
same problem...
Sorry... another solution?
P.S. I don't have reset the phone after update... I should do it?
THanks
BeHa
Wed Nov 16, 2016 9:00 pm
For me solution was "proximity sensor calibration"... about 5 times in a row and it is working fine since then.
Thu Nov 17, 2016 7:42 am
Setting menu-developer option, then recalibrate the proximity sensor.
Thu Nov 17, 2016 7:44 am
