mobosenshi
Loose part
Wed Sep 28, 2016 8:47 pm
Has anyone experienced loose parts inside of the BV6000? I noticed it this evening. I think the battery is detached inside.
Re: Loose part
Thu Sep 29, 2016 7:24 am
If anything wrong, you can contact your seller for repair.
mobosenshi
Re: Loose part
Thu Sep 29, 2016 8:56 am
Hi admin,
The phone works 100% :D
styxxx
Re: Loose part
Thu Sep 29, 2016 4:52 pm
Yes me. I have the feeling something started to move a bit when turning the phone. It's still working perfectly. And I didn't drop it. Also assumed the battery since it feels like it's something heavy. I wonder if I should fix it or ignore it. I don't want to live without the phone while it's being repaired :P
mobosenshi
Re: Loose part
Thu Sep 29, 2016 6:28 pm
Today it is less loose. Maybe the battery stuck back on the glue :lol:
mobosenshi
Re: Loose part
Wed Oct 12, 2016 10:30 am
admin,
I've seen Blackview BV6000 Teardown Review Disassembly & Assembly on Youtube. The internal battery appears to be lightly glued. It looks like clear gooey glue solution to me.
If I disassemble the unit myself, would it void my warranty?
mobosenshi
Re: Loose part
Mon Oct 17, 2016 1:05 pm
Bump :D
mobosenshi
Re: Loose part
Wed Oct 19, 2016 7:04 pm
Well, admin?
Petas3
Re: Loose part
Wed Oct 19, 2016 9:25 pm
As with everything. Going inside will probably void the warranty - depends on your skills, video guide is good. If you bought on AliExpress and such, there is little possible support from seller that wont cost you a lot of time and postage.
mobosenshi
Re: Loose part
Tue Oct 25, 2016 6:48 pm
I just want to know the type of glue used. It would be a waste of time to ship my BV6000 to Asia and wait God who knows how long for a RMA :(
