tammbuhez
Random SMS reception
Fri Sep 23, 2016 6:23 pm
Hi Blackview_admin,
Didn't find how to answer to your response so I'm creating a new topic.
All settings about SMS and MMS are right, I verified at least ten times ;) And there is no setting blocking SMS.
I'm pretty sure the problem come from the app I was using (Messenger from Google as it was my previous SMS application on Nexus5), I set the SMS application shiped with the ROM as my default SMS application and it seems that I receive all SMS and MMS.
Therefore I wonder what is the root cause on this application that I used for a long time without issue on my previous device. Any idea?
Regards,
Re: Random SMS reception
Sat Sep 24, 2016 5:52 am
tammbuhez wrote:
Hi Blackview_admin,
Regards,
Now you can receive SMS and MMS on BV6000 with the proloaded SMS app ?
