gerrie
SD card
Wed Sep 21, 2016 11:40 pm
What sd-card can i insert in the bv 6000? 64 gb or even higher ones?
Re: SD card
Thu Sep 22, 2016 6:14 am
http://blackview.hk/blackview-147/
kup0
Re: SD card
Thu Sep 22, 2016 11:39 am
64gb Transcend sd-card works fine with my BV6000.
itachi
Re: SD card
Fri Sep 23, 2016 8:49 am
will it support 128/256 gb sd card??
Re: SD card
Sat Sep 24, 2016 6:11 am
Support 32GB TF card, if you put the larger one, the card may be demaged.
gs69foot
Re: SD card
Sun Sep 25, 2016 9:24 pm
Hello,my BV6000 doesn't recognize my SD card ,what is the procedure?
What should I do to install one? :?:
Thanks for answer. :)
MasaKini
Re: SD card
Mon Sep 26, 2016 1:05 pm
I confirm that my MicroSD card :
Samsung Pro+ 128 GB
Can work well on BV6000
