Pedro74
bv6000 volume problem
Thu Sep 15, 2016 12:26 pm
Hi phone was working fine but now sound so quiet can't hear ringtone or alarm or video all volume controls are set to max please help.
Re: bv6000 volume problem
Mon Sep 19, 2016 6:26 am
The sound was always quite after you received it ? or it worked well before but just suffers such a situation suddenly ?
theofanousi
Sat Feb 25, 2017 6:11 am
Hi
I also have a problem with the volume of my phone. It was working normally for the last two months and now the volume of the speaker is very low. All the volume settings are full. Please help because I really like this phone and I do not want to throw it away.
Kind Regards
Ioannis Theofanous
theofanousi
Sat Feb 25, 2017 6:12 am
Hi
Kind Regards
Ioannis Theofanous
Hood
Mon Sep 04, 2017 11:40 pm
Mine has also become very quiet, as others have said all settings are at maximum.
Is this a speaker problem? Is there any way to cure it?
I keep missing messages and calls because I do not hear the phone.
Tue Sep 05, 2017 7:09 am
If you can listen music on your phone, if not, then you should replace another new speaker.
Hood
Tue Sep 05, 2017 9:18 am
I can hear the music and the quality is good but it is very quiet, same with ring, notifications etc, in fact any sound via the loud speaker is very quiet.
Users browsing this forum: Baidu [Spider] and 1 guest
