dukulis
BV6000 no OTG at all!!!
Tue Sep 13, 2016 7:04 pm
Two days ago I get this phone, with latest OTA update. But no one device not working when connecting to USB. NO OTG function !! Please help!!
I will hope that I not again spent my money for crap from Black view!! With First crap BV5000 I have expierence.
Re: BV6000 no OTG at all!!!
Sun Sep 18, 2016 8:41 am
BV6000 really supports this function, and please try another OTG Cable to see it problem still exists ?
marcosub09
Sun Sep 18, 2016 9:25 pm
I have the same problem. I tried another cable OTG but usb dosen't work. Any solution?
fabiandaniel
Tue Sep 20, 2016 12:17 pm
I tried with other OTG cable but it can't work. The original OTG cable work with my other android phones.
david99
Wed Sep 21, 2016 7:57 pm
Yes, otg don't work with bv6000. The cable is good because it is work perfect with other devices.
Fri Sep 23, 2016 7:50 am
we are trying to find why this happen and then will give a solution as soon as possible!
Fri Sep 23, 2016 8:01 am
We has tested this phone can work perfectly with OTG function.
We are also trying our best to find the reason why this happen, please give us some time, we will provide a solution as soon as possible.
Fri Sep 23, 2016 8:02 am
We are trying our best to figure out why this happen, and give a solution as soon as possible.
chrisb
Fri Sep 23, 2016 12:02 pm
Also fix the problem with android pay
Petas3
Fri Sep 23, 2016 7:17 pm
Firmware 20160822 - Decided to test out of curiosity, OTG not working.
Also having slight issues with proximity sensor (but this could be screen cover issue).
