asdf747
Can´t connect to Win 10 and mobile data doesn´t work
Mon Sep 12, 2016 7:08 pm
Can´t connect to Win 10 PC....need a driver device the link you send me last time doesn´t work.
My mobile data doesn´t work ... the phone shows the 3G icon but roaming is always on.
If I need to use the web it doesn´t work because I´m not connected?!
WLAN works fine...
Re: Can´t connect to Win 10 and mobile data doesn´t work
Tue Sep 13, 2016 5:46 am
WLAN works fine...
After installing the driver, if you have restarted the computer?
