Belen
4G Coverage problem
Mon Feb 15, 2016 7:32 pm
The phone does not have 4G coverage. I tried the sim card in another phone and and it works the 4G coverage . The Blackview phone has 4G enable but the notification bar only shows the indicator 3G, I do not know what happens
Re: 4G Coverage problem
Tue Feb 16, 2016 6:51 am
Hi ,
could you check if your smartphone is BV2000 or BV2000S ? they are so similar, but bv2000s can not suport 4G.
Best regards,
Admin
Belen
Tue Feb 16, 2016 8:14 am
OK, my model is BV2000, I'm sure about it. On other phones that I have the same company 4G signal appears but does not appear in the BV2000
Belen
Wed Feb 17, 2016 8:47 am
I'm sure that my model is BV2000 with 4G support.
Belen
Sat Feb 20, 2016 8:39 pm
Please , why do not you answer me? I'm sure that my model is Bv2000, the firsts days the phone had 4G and now the phone does not have it
Hidraulico
Mon Mar 07, 2016 10:02 am
That has happened to me after upgrading. Do you have updated?
jackbox
Mon Mar 21, 2016 1:27 pm
If the 4G signal is weak then the phone will revert to a 3G signal.
