asdf747
Driver for Win10
Sun Sep 11, 2016 7:13 pm
Need a driver to connect my BV6000 to my win 10 PC
Re: Driver for Win10
Mon Sep 12, 2016 7:52 am
bulecki13
Mon Sep 12, 2016 9:00 am
That not working
asdf747
Mon Sep 12, 2016 6:59 pm
This doesn´t work for Win10...
Tue Sep 13, 2016 6:50 am
bulecki13 wrote:
That not working
after installing , try to restart your computer, usually it works.
if still with problem, hope the the file named as "solution to MTK error
on windows 10 " can help you.
download the PDF file via the following link:
https://mega.nz/#!H8UECTJB!BPTzYIC9JAeP ... tn3Is8_s30
Colin
Tue Sep 13, 2016 5:43 pm
Same here
Fra17k
Fri Sep 16, 2016 9:51 am
After restart, under device manager. Mine showed in other devices not portable device. It came up as an unknown device. I chose update driver then seach my machine for driver and the device I chose was MTP with USB and that worked. Now shows up as android phone in DM and appears in this pc. Hope that helps everyone
MasaKini
Sat Sep 17, 2016 4:53 pm
Try this official drivers from MediaTek guys.
http://www.mediatek.com/en/downloads1/downloads/
I hope it works.
Users browsing this forum: Google Adsense [Bot] and 1 guest
