bandawo
Bv6000s stuck in endless boot loop.
Sun Sep 11, 2016 5:12 pm
Hi can anyone help me fix my bv6000s which is stuch in endless boot loop.
Thank you
Re: Bv6000s stuck in endless boot loop.
Mon Sep 12, 2016 7:26 am
try a factory reset to see if it can work properly
Noshkov
Tue Oct 25, 2016 6:08 am
I have the same problem. When I press the power button to lock or unlock the phone lowers the volume. Looks like it makes bad contact. I did the factory reset and even erased all my data on the SD card. But the problem remains. I hope you're gonna help me while I'm having bad times with the seller's comunication.
Thank You.
petikacsa
Fri Aug 04, 2017 3:02 pm
Hello this is my problem. I can not enter recovery mode
Wed Sep 27, 2017 11:41 am
for boot-loop flash the latest firmware over pc.
