kup0
Widgets don't update
Sat Sep 10, 2016 5:59 am
I just noticed that my widgets are not updating. I use Nova launcher prime and never had this problem with previous phones. Is there something in settings I have missed?
Re: Widgets don't update
Sat Sep 10, 2016 7:37 am
Try a factory reset.
kup0
Sat Sep 10, 2016 10:13 am
Problem was "background task clear". I turned it off and widgeds work again. There was no need for factory reset!
Petas3
Sat Sep 10, 2016 8:47 pm
Thanks for the tip. Background task clear is the key to solving many issues.
