Colin
USB transfer fault
Thu Sep 08, 2016 8:24 am
The USB confection has a fault when I connect to computer only the USB charge function works all other functions font. When I check device driver it it shows up but displays code error 19
I have tried swapping cables and tried on different computers same problem.
It did very briefly work then it stopped
I've sent same via facebook messenger also a couple of pictures
Re: USB transfer fault
Fri Sep 09, 2016 6:15 am
what's the system of the computers you try ?
Colin
Fri Sep 09, 2016 8:39 am
Window's 10 tried on 2 computers neither work
I've also tried different cable same problem
I see you have put up a device driver how do you install
Derk
Fri Sep 09, 2016 5:31 pm
Try the following:
- go to Settings -> About phone
- scroll down to Build number
- tap on Build number 7 times -> this unlocks the developer options
- go back one level and just above About phone you find developer options -> locate the setting "select USB configuration"
- on your phone I guess this is on "Charging only", choose whatever you need
Colin
Fri Sep 09, 2016 6:36 pm
Tried that one its set to MTP
More suggestions pls
Colin
Sat Sep 10, 2016 6:04 am
Tried this still doesn't work
Sat Sep 10, 2016 8:14 am
Try to install the driver on your computer.
downloading link :
https://mega.nz/#!L8dx2QSB!rjy7p4ve9URF ... 2PeDIMGfLM
If still can not work, after finish installing, reboot your problem , this usually work !
Colin
Tue Sep 13, 2016 5:42 pm
Still strugggleing to connect to windows 10
I have down loaded and installed the recommended updates and drivers still getting various error codes which I could forward to you if you provide the means
Is this forum the only means of getting support??
If this problem is not resolved I wish to return the phone under warranty how do I progress this option
Thanks for your very limited support
Colin Perrin you
bovirus
Tue Sep 13, 2016 6:04 pm
- Disconenct the device by PC.
- Open a DOS primompt with admin privilege
- Type the following command
Net localgroup Administrators localservice /add
- Check that teh answer is commande xecuted (without errors)
- Close the DOS prompt.
Connect teh device to USB.
Wed Sep 14, 2016 7:06 am
Colin Perrin you
This is solution file for windows 10 connecting error to MTK device.
Download here :
https://mega.nz/#!H8UECTJB!BPTzYIC9JAeP ... tn3Is8_s30
