Don Harry
OTA dont find updates
Tue Sep 06, 2016 3:11 pm
Dear admin,
is the a trick to get OTA`s? The phone got V1_20160608 and cant find updates.
I would prefere a OTA instead of a ROM.
Re: OTA dont find updates
Wed Sep 07, 2016 8:49 am
The OTA update is automatically pushed to the smartphones.
If you fails to get the OTA update, now can just get a update via PC.
We have publish the manual and tools, if you need, you can find on the
ROM Board of BV6000.
Thanks!
Don Harry
Wed Sep 07, 2016 11:32 am
Thx for info,
do you have a update (OTA) to download manually for using local update option?
Andrew1974
Wed Sep 07, 2016 6:08 pm
blackview_admin wrote:
Thanks!
Hello, I am in possession of a smartphone bv6000 ( with firmware 20160608 ) but I do not receive the OTA and I can not load updates through flash tool ( incorrect installation of drivers) . I state that I have followed your guidance on the forum but I can not . It would be possible to find the OTA download for local installation ? Better would be the full OTA OTA and not incremental .
I await response.
Thank you
Greetings
Thu Sep 08, 2016 7:09 am
Don Harry wrote:
Thx for info,
Sorry to tell now we now do not such a local update option,
I will pass this feedback to our software department to see if
it is possible to provide one.
Best regards,
Admin
Thu Sep 08, 2016 7:13 am
Thanks!
I await response.
Thank you
Greetings
We will consider providing local update to help more people. please give us more time.
