Petas3
BV6000 20160822 Wireless Update
Fri Sep 02, 2016 7:53 am
I have decided to test the upgrade, going from 20160713.
There is 1 middle step. You first need to upgrade to 20160812.
Upgrade is a success. The phone works for me so far.
*Compass issues resolved
*Lockscreen issues resolved
Write your experiences below..
ravee1010
Re: BV6000 20160822 Wireless Update
Fri Sep 02, 2016 1:33 pm
Everything looks good now except battery draining issue . Battery was excellent earlier , now doesnt last 20 hours after the update . Hope they fix it ASAP.
Jacque
Mon Sep 05, 2016 11:32 am
I cant get my USB3 (OTG) to be connected and not disconnecting itself.
What can be the problem?
SnuffThePunkz
Sun Sep 11, 2016 4:34 pm
Glad to hear a positive review, had some bad updates with old phone. Guess I'll start backing up for the update.
Users browsing this forum: Baidu [Spider] and 6 guests
