yoavCrystal
Screen Replacment
Thu Sep 01, 2016 11:13 am
My BV5000 screen broke some time ago.
I have orders a new screen and sent it to a lab to replace it.
The Lab tech failed to replace the screen, and said i have order the wrong screen type (just a blank screen).
First is this really a possibility or should the we just replace the ROM.
if i did order the wrong part were can i buy the correct one ?
the numbers on my screen are the same as the link shown in the form, but they do not supply the screen any more :-(
tnx
yoav
Re: Screen Replacment
Fri Sep 02, 2016 7:54 am
yoavCrystal wrote:
tnx
yoav
Send email to service@blackview.hk.
you will get a answer for your problem.
