Re: A problem with displaying the battery as a percentage.
Mon Aug 29, 2016 10:05 am
nesterov32 wrote:
Good evening, my name is Dennis, I'm from Russia. I decided to buy your smartphone Blatskvyev BV6000s, everything in it is large enough, but there is a but! The problem with the battery. Rather displaying percent battery, smartphone worked today on a charge of 1% from 15-00. It is possible that the software, using the firmware to fix this thing?
You want to say the power indicator is wrong ?
Best regards,
Admin
