Tonillovera
Problem with camera
Sat Aug 27, 2016 2:55 pm
Hi, I have a Bv6000, my rear camera does not work and the front one is 180° rotated, I've tried to upgrade firmware but says my device is currently up to grade, the sellers told me I can try to change the ROM, the version is 20160608 but I don't know what Rom I have to install to repair the camera and how to do the installation, can anybody help me?
Best regards.
Ajiw
Re: Problem with camera
Thu Mar 30, 2017 12:15 pm
You got the same issue just like currently I have
Have you solved it bro ? I need some help to overcome of this issu
Ajiw
Thu Mar 30, 2017 7:43 pm
I have the same problem suchlike this one
